Use CLI to verify your installed software. It is important to verify your software version before you place a device into a production environment.
  1. Enter Privileged EXEC mode:
    enable
  2. Verify the software release:
    show software detail
The following is an example of the output of the show software detail command.
Switch:1>show software detail
                    software releases in /intflash/release/
5420.8.5.0.0.GA (Primary Release) (Signed Release)
  SSIO
    UBOOT                            2.3.2.3
    APP_FS                           5420.8.5.0.0.GA
  AVAILABLE ENCRYPTION MODULES
    3DES
    AES/DES
5420.8.4.0.0.GA (Backup Release) (Unsigned Release)
  SSIO
    UBOOT                            2.3.2.1
    APP_FS                           5420.8.4.0.0.GA
    3DES
    AES/DES
